주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
563 질문 전체 보기
No battery detection with new Logic Board
Hi I have a A1708 with function keys. After dead logic board I ordered a used one of eBay. Replaced and booting up. First completely erased disc and made full install of delivered high Sierra. Then I saw that no battery is detected (PPT001 in diagnose). Boots up and schows 100% and X in battery symbol. At a short moment it showed battery 0%. Made SMC reset…nothing. High chance of high discharged status of the battery but my usb c tool only shows 0,5A when running…so it’s definetely not charging.
what is the problem with “new” logic board and old battery ? Is there any workaround? Thx on advance
Update (12/14/2019)
Looks like there is something wrong with dates?
Had the Problem with date at new installation of High Sierra with “CERT” failure because date was set to 19xx.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 9개
Run CoconutBattery and post a snapshot here for us to see 기존 질문에 이미지 추가하기
Does coconut Display different results than System report? System report says no battery detected
It offers a better view and boils it all down into a more compact screen. Please let's see what it shows us.
For reference: Battery suddenly not recognized. MBP Fn 2017 which has a similar problem.
Posted it down below. Strange thing is, when I start up and the apple logo and statusbar is on screen and I pull the cord, then it loads till system is "up"...then it shuts off.
@BenjaminS - This makes sense! When you disconnect the USB-C power cable the system looses its settings so the date reverts to the default 1979.
댓글 4개 더보기
댓글 달기
답변 3개
선택된 답변
Thank you dan for your advice.
SOLVED:
It was the “Data-Cable” which connects Battery and Main Logic-Board. Just replaced it with a new one and its working again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You need to replace the battery as the micro controller within it is not working so its not charging properly. Here’s the needed part MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery you’ll need to reference this guide MacBook Pro 13" Function Keys Late 2016 배터리 교체
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Battery 이미지
상품
$129.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Are you sure ? Before replacing the Board everything worked fine. Are there any probe points or another way to test the battery? When I measure simple at the two contacts on the Battery board I get 5,8 V ...seems a little to low? Does anyone have voltages to test ?
Sorry you've damaged it somehow.
Starting in single user mode and pulling cord stays on. Only when exit single user mode shuts off
OK, so what does CoconutBattery say in Single User?
@BenjaminS - Happy it all worked out! Don't forget to score the answer and accept it so its closed out.
댓글 달기
Hi, lately I installed an NVME M.2 ssd and after unplugging the battery board data cable I ripped of the head. After installing everything and plugging everything the MacBook don't start anymore with the battery and it doesn't show up on the sidebar. I ordered a new battery board data cable and plugged that won in with no results. Am I missing something ?? any setting ?? or manipulation ?? I did everything step by step. Please help !!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@agredach - Best to create a fresh question. This series uses a custom SSD it does not offer a M.2 interface for a M.2 SSD.
댓글 달기
귀하의 답변을 추가하세요
BenjaminS 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 627
