주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
MacBook Pro not turning on
Hello,
The issue I am having is my mid-2014 13’’ retina MacBook pro is not turning on. If I plug in the MagSafe power cable it will turn orange, I could leave it plugged in for days but it will never go green. I have tried resetting everything and checked all connections on the motherboard and they look fine. I can hold down the power button and nothing happens.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
This sounds like a dead battery.
Can you give us some more details. Like if it was dropped or got wet at some point (liquid spill). Do you run on battery a lot and tend to let the battery run all the way down before recharging. The more details the better
No drops, damages, or liquids. Use it on a charger most of the time.
댓글 달기
답변 2개
선택된 답변
Try opening up the bottom, disconnect battery from the logic board and reconnect magsafe to rule out a possible battery fault preventing startup. Other than that there’s not much you can do on your own beside finding a lab into component level repairs or try to replace your logic board.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Yeah, I tried that from what I found on a post here but it didn't do anything. Ok, I was hoping to avoid going somewhere but it sounds like that may be the best bet. Thanks for the help.
댓글 달기
It sounds to me like your battery has an issue. Have you tried disconnecting it and starting the machine? It could also be the macs internal charge port that has blown do to a short. Check the Magsafe carefully to see if there is any small metal part that has been attracted to the magnet. This will short the Magsafe and cause it to not start until you either install a new Magsafe or repair the charge controller within it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rob Whitlow 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 164
