UL code even when it is empty - bolt on bottom was not loose - HELP
I have been getting the UL error code on almost every load and even when it is empty for the “clean washer” cycle. I flipped it over and made sure that the bolt on the bottom was tight as some others had success after doing that - but it is still doing it. I have noticed that the whole drum seems to not be centered when I open the lid and if I get the code, just pulling it towards me, clears it…until it starts up again. But EVERY time I reset it, it starts filling with water again and so it just ends up being a long viscous cycle of trying to get it to finish those last 12 minutes over and over again. Is there a way to re-center the drum if it is sitting towards the back of the unit…or could that even be related to the issue? Thanks so much for any help you can provide!
좋은 질문 입니까?
