주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Home Button Not Working After Screen Replacement
So a month or so ago, my boss came up to me and asked me to fix his iPhone 7’s broken screen. I swapped the OEM broken screen for a cheap $20 replacement screen from Nasteck, and everything worked fine, until my boss dropped it off of the coffee table and shattered the cheap screen. This time, I ordered the $70 replacement screen from iFixit, but when trying to transfer the home button over, the connector wouldn’t snap together. I tried snapping the home button onto the broken Nasteck screen, and it wouldn’t work either. I’m worried that the original home button is now broken, and Touch ID is gone forever. Can I send in the iFixit screen for warranty/refund?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Customer service is at: https://help.ifixit.com/
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I tried re-connecting the original home button to the new iFixit screen, and now the Touch ID fingerprint sensor works but the home button itself doesn't actuate. What's the most likely culprit? My best guess is the home button flex connector itself isn't making complete/proper connection, but if anyone knows anything different, any advice is greatly appreciated!
@bludude4 Usually a tear in the home button flex cable or screen to logic board flex is the culprit. A damaged connector is the other alternative. A visual inspection with a good light source and preferably a microscope are needed to spot very small damages.
댓글 달기
귀하의 답변을 추가하세요
Tom Christie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 76
