주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
Will a screen replacement fix flexgate?
Hey, I'm a apple customer from India. I'd bought my MBP 2016 15 inch in late 2017 and have just detected the beginning of flexgate today, the 26th of December 2019(The spotlights have appeared). What I need to know is whether a screen replacement is a permanent fix for the same . That is, does the official screen replacement have a longer cable? Or is it still prone to flexgate after a year or two of usage?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Apple is replacing the full display assembly with a newer version which does have a longer backlight cable.
Depending on supplier an independent shop may not have the newer part.
이 답변이 도움이 되었나요?
점수 2
댓글 5개:
Do you have a part # on the newer display yet?
Thanks so much, really appreciate it
@mayer
The newest version P/N's
661-08030 - Space Grey
661-08031 - Silver
Does the replacement also include 15-inch MBPs?
@LEON PATRICK MAWLONG - Apple does not have an official program for the 15" models. But! Don't give up! You'll need to visit a real Apple Store and make your case for a warranty exception. You will need to be able to show them you haven't damaged your system in any way and the movement of the screen cuts the backlight on and off or gets stage light effect.
댓글 달기
답변을 추가하세요
Jason Sequeira 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 1,583
