주요 콘텐츠로 건너뛰기
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 질문 전체 보기
screen replaced, but buttons dont work
I recently replaced an evo screen like normal but this time when u hit home on the new screen or any of the bottoms button I get no response except for it hits the bottom of the phones option whatever is above the button I select Wat do I do ?????
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
You likely didn't connect the cable going to the digitizer correctly. Before you do anything else, take the iPod apart again reconnect the digitizer until the connection is fully flat.
If this doesn't work and the rest of the iPod is good, you likely have a defective replacement digitizer.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks but I took it apart and realized the ribbon for the digitizer was pulled flush all the way through to the back of the lcd... it folded before touching the lcd not firm and pulled tight and flat thank you though started to go crazy
댓글 달기
귀하의 답변을 추가하세요
joe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,394
