주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Camera focus after case replacement
I recently replaced the assembly of an iPhone 7+. However I’m noticing that the camera images are blurry regardless of zoom setting.
When I take the phone apart, and remove the camera from the “port” it sits into, the camera is no longer blurry (I tested while the phone was apart and camera lens moves in and out and focus is perfect). As soon as I put the camera back into it’s spot, the camera is blurry. The lens is perfectly clean.
I have a feeling that when the camera is placed in the port, the actual camera lens can’t “zoom” and physically move.
What am I doing wrong?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Same problem here, after replacing the glass at the back of the rear camera with the middle part also, couldnt fix de alignament bracket properly , and the conclusion is no focus on the camera, also the selfie camera no longer works. So, i sugest a new case, original, is the only way to fix these problem, this what i will do.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi, were you able to fix this problem? i have a similar issue with my 7plus
댓글 달기
귀하의 답변을 추가하세요
SynPDX 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 238
