주요 콘텐츠로 건너뛰기
Google's 2nd-generation Pixel XL sports a 6-inch P-OLED display with rounded corners. Available in 64 and 128 GB storage configurations, and in two colors: Just Black and Black & White. Released October 19, 2017.
72 질문 전체 보기
Pixel 2 XL not fast charging after battery replacement
I've been using my newly replaced Pixel 2 XL battery (purchased from iFixit) for a little over 2 weeks now, and I've noticed that it charges very slowly when using 18W PD certified fast chargers. It charges faster via a normal 5V/2A USB adapter than the OEM 18W adapter, and I've also used an Anker fast charger which also charges very slowly. I tested charging speeds using AccuBattery and the phone regularly pulled under 1A on the fast chargers, while regularly doing 1.3 on normal ones. The actual charging speeds resulted in something like 48% to 54% in a span of 36 minutes.
One hypothesis I had has to do with the temperature-related charging speeds of the 2 XL - multiple sources have cited the phone not fast charging if the battery is under 20°C (68°F). Testing across multiple apps (GSam, Ampere, etc) it seems that my battery temperature reading is locked at about 20.8°C, which is very close to the threshold. Does the iFixit replacement battery match the spec of the OEM battery to get temperature readings? It's also possible that the connection isn't fully connected. Can anyone else with a iFixit 2 XL battery replacement chime in?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
I had a similar problem and found the issue was with the replacement battery. under the black tape of the battery is a small PCB. The replacement one I had from a different vendor had a different PCB. I desoldered the PCB from the original and soldered on the new battery. So old PCB with a new battery cell and it regained the fast charge ability.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Boy I hope you still read this: did you swap just the ribbon cable or the whole PCB? Looking at the terminals on my original and the replacement battery, the terminals from each of the cells don't line up such that it will be possible to swap the PCB without *maybe* offsetting the PCB to hopefully line up.
댓글 달기
귀하의 답변을 추가하세요
Evan Lee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 616
