주요 콘텐츠로 건너뛰기
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
42 질문 전체 보기
Would Sugru work to fill this in?
I have a Wii I explicitly bought to use as a Component Gamecube, due to the cost of actual Gamecube component cables. I may use it for Wii games, but I also didn’t even use the one from 2007 for games most of the time and that was a shared Wii.
The controllers work, but the grips have always been gone as long as I have owned them. I tolerate it, but now I think I’m going to use it enough to justify rebuilding the grips.
I am looking at trying white Sugru or an epoxy stick and matte spray paint to fill this in best I can and make it look flush. Either way, I will need to sand it.
Out of both of these materials, which one would be cheaper to use while still working as a filler? I don’t know what type of plastic they are (iconcepts game fury) but I know clone controllers enough to suspect ABS.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
I use sugru to fill in small holes but this looks like a job for a clear epoxy plus it would be nice and smooth.
해당 답변은 도움이 되었습니까?
점수 2
4 댓글:
Yeah - I figured it looked like an epoxy job. I decided to look into the stick type because of how small one low is - I have attached a photo with an Exacto knife as a reference point. Would have been nice to use Sugru since it doesn't need paint though.
I would need paintable epoxy because I want the controller to pass as much as I can. What I may need to do is tape it over, fill it with epoxy and sand it as needed IF I spill.
Look at the white epoxies, paint comes off. https://www.amazon.com/Pratley-Quickset-...
@mayer I have a original bumper left :-). I can make a mold, use Epoxy to form it and rebuild without messing with the controllers.
Remember that if you are using just standard mold making material, your result will be smaller.
댓글 달기
귀하의 답변을 추가하세요
Nick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 193
