LCD dead after housing replacement!
I just replaced my back housing but now the LCD and digitizer won't work! The phone is on because music plays from the headphones.
Any ideas?
좋은 질문 입니까?
Any ideas?
좋은 질문 입니까?
Try cleaning connectors 1&2. Check the pins for any damage. Then if still no effect you could try taking board out for 20 minutes or so (seems to rest the board in some cases.. Had this happen with one of mine when LCD wouldn't work) if that doesn't work try restore in iTunes(backup first!) if that doesn't work try new screen
해당 답변은 도움이 되었습니까?
Check your ribbon wires on your iphone to see if any of them broke or unplugged during your installation
해당 답변은 도움이 되었습니까?
There is a teardown spot for iphones here on this site you can go by to check and see if any cables are disconnected
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 773
댓글 2개
tried a reset? press and hold power and home for 10 seconds..apple should appear, then allow to reboot.
pollytintop 의
I checked all the cables! Played around with them for like 30 mins but nothing. :( Any other ideas?
Jeremy Scalpello 의
