주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
USB 2.0 및 Firewire 400/800 인터페이스를 갖춘 외장 드라이브입니다. 320 GB에서 2 TB 사이의 용량으로 출시되었습니다.
Data Recovery Issues after restore
Hello everyone.
I have a western digital which I had stored videos from my macbook pro using the software final cut pro.
About a week back the hard drive crashed and I took the external hard drive and attached it to a PC running windows 7 and ran a recovery program called EASEUS recovery. I was successful recovering the the videos , but I can't play the videos neither on a mac or pc. Keep getting an error that the file is invalid. Is there a special software or a particular way to run recovery which would enable me to recover the videos properly.
All help is appreciated
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Hi can i suggest that you check one if the files info and comfirm if the size of the file tally with what you have?
의 공유
댓글 달기
답변 3개
선택된 해법
I would contact the maker of the software you used for assistance. They probably used a file system locked to their software and should be able to tell you how to make it readable again. If they can't help you I would contact WD for help. Save the drive -- you may need to recover again.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Use free tool called Disk Drill, to recover your deleted videos. It's very important to preview your files before recovering. http://download.cnet.com/Disk-Drill/3000...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If you can not open the video, that means the video was not recovered completely. Try other better video recovery program like Card Data Recovery.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
hello,
Ok the issue is the data was lost on a mac and the recovery was done using a windows pc that is the reason the files seem to be corrupted. Is there a software or solution to convert it back to mac format.. thanks
의 공유
Probably not, because you now have a corrupt file structure, It can not simply be fixed by converting to mac format.
의 공유
댓글 달기
답변을 추가하세요
cyrus s 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 22
전체 시간: 3,740
