주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
563 질문 전체 보기
MBP 2017, black bars across screen, display failure.
Hi
My 2017 MBP has been developing a display fault resulting in a large black bar across the screen. This device was purchased refurbished at the start of 2018, and thus the 1 yr ltd warrenty is no longer active, but my statutory rights still stand (EU). From some research here and elsewhere it seems to be common, but not common enough to warrant a recall program.
The device is currently with an AASP, and according to them the GPU or another display component has been fried due to inadequate cooling.
The question is, would you consider this an inherent fault with the device? and has anybody sucessfully had an issue like this rectified without paying for it?
Video:
https://youtu.be/jdgd40N_n_U
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
This issue was covered under a warranty exception after presenting Apple with a tech report / repair quote
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
You need to hook it up to an external monitor to confirm the diagnostic.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
AASP confirmed this using an external.
Fine, as long as you saw it and not just them.
More often the internal displays T-CON board has this issue which won't show up on an external monitor. I would double check is you have the grey bar on it.
If the external's image is clean then you'll need a new display assembly, as the T-CON is part of the display via a set of ribbon cables.
As far as fault. In my option this is a design failure as the T-CON board is placed near the heat sink cooling fins. The lack of cooling either because the fans failed or the vents where blocked so air was not able to flow across the fins would be the root cause.
I would press for a warranty exception! As Apple should take responsibility.
@danj Thanks for your advice, they did indeed take responsibility for this issue.
댓글 달기
귀하의 답변을 추가하세요
padrick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 388
