주요 콘텐츠로 건너뛰기
냉장고, 냉동고 및 냉장-냉동고를 포함한 식품 냉각 장치 수리 및 분해 안내서.
1699 질문 전체 보기
freezes up so only the freezer work
I have a 2018 built in GE monogram french door refrigerator and every 2 or 3 months it freezes up so only the freezer works, GE told me it was my fault and we probably were not closing the freezer door completely, I have methodically checked this and it still freezes up so assume it is defective, my warranty runs out in August so need this fixed, any one had similar problems
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Please give us your exact model number.
댓글 달기
답변 2개
선택된 답변
Russell, I’d suggest calling GE back. Doing any repairs yourself could void your warranty. I would request a different technician to come out to diagnose the issue. If you aren’t shutting the door completely, your freezer wouldn’t be freezing properly either. Most people will notice the door open because that refrigerator has an alarm that beeps. I’m not buying what the technician told you. Especially if you’ve been making sure the door is closed.
The issue your experiencing is typical for a defrost problem, gasket issue or a fan motor. Either way, it is all under warranty and you should not have to pay for repairs
You have an expensive, top of the line refrigerator and your warranty is to protect you from costly repairs. The right technician will be able to solve the problem. Unfortunately, not all technicians are the same. Request a different technician or even request the lead tech. People do it all the time. Use your warranty while you can.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Depending on the model, which you didn't provide there could be five possible problems:
  1. Main board
  2. Defrost time
  3. Defrost sensor
  4. Defrost element
  5. Fridge needs to be pulled out and coils vacuumed and cleaned
When I had the problem, it was ther defrost element. If everything else is working, I doubt it's the main board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I probably should've said at least 5 possible problems. I'm sure I overlooked a couple.
댓글 달기
귀하의 답변을 추가하세요
Russell Boxall 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 58
