Earphone speaker working but front camera is not..
My earphone speaker is working but the front camera isn’t.. Can you help?
좋은 질문 입니까?
좋은 질문 입니까?
Yes, this may seem quite simple, but probably just a faulty camera. It’s quite simple to replace, just buy a new camera and fit it as you would with a screen replacement.
해당 답변은 도움이 되었습니까?
Thanks for this. I am learning to fix so bare with me but can you just confirm.. It's the actual camera not the flex cable? As if it was the flexcable surely the earpiece speaker wouldn't work either would it.. Is that correct?x
Great question, and a good point. I’m still learning myself, but I think that you’re correct, however if the new camera still does not work, a new flex cable could possibly be partially damaged. In sort, yes, I think just a new camera.
Had a similar issue with a 6S, a front camera flex that appeared perfectly fine, earpiece mic (Siri mic) worked fine, proximity sensor and earpiece speaker were fine, just the front camera not working. Replacing the entire flex is probably the way to go just to be safe
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 73
That all makes sense now. Just trying to get to the logic. Thanks!
jsymes 의
