주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
Which SSD upgrade should I go for
So, i am about to buy the SSD upgrade for my mac and i have two choices...
OWC Drive with Read of 501mbs and Write of 503mbs at £186. This drive is made by a company.
https://www.thebookyard.com/product.php?...
or
Fledgling P12 with Read of 473mbs and Write of 465mbs at £141.15. This drive is not made by a company per say but is the result of crowdfunding for more affordable drives for the macbook pro.
https://www.ebay.co.uk/itm/1TB-Solid-Sta...
So my question is this. Do i go with the cheaper one or will the 28mbs / 38mbs make enough of a difference on my mid 2012 retina that it would be worth paying the extra £45
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I'd go for the P12. I know that 3rd party SATA based SSD adapters and SSDs are fine. It's the PCIe based one that is unreliable.
What is the warranty on the cheap one? I just wrote the company to try to get more information on them.
댓글 달기
답변 2개
선택된 답변
It shouldn't make a difference, my bigger concern is the quality of the product between the two and not so much the write speed. I sincerely doubt you will notice any major difference between the two so if you consider them both a quality product, go with the cheaper one.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You’re not going to notice the difference. I know some people do not like OWC drives but I personally use then in my machines and have zero issues. Just be aware if you plan to use an adapter you may run into fitment issues. Good Luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Skyler Chie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 63
