주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
iPad 2 wont connect to open WiFi network
When i try to connect my iPad 2 to the guest WiFi at my school, it just has the loading circle and wont connect, however it will connect to my home WiFi perfectly fine showing the little check mark. i have tried factory resetting the internet options and it did not work.
Update (01/16/2020)
PROBLEM SOLVED!!! After a quick factory reset on the iPad it will connect to my schools WiFi
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Have you tried opening a browser? Usually with these cases you are required to login some other way besides using just the Wifi password, especially at a school. Check with your front office, they probably have the login information (unless it's not actually a guest account for students, in which case you're probably out of luck by normal means)
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
i have tried opening both chrome and safari, and going to an HTTP website such as www.cnn.com but it doesnt redirect to the internet login page
i have also used this guest WiFi perfectly fine on other devices such as my phone, and the school uses it on some of their computers aswell
댓글 달기
귀하의 답변을 추가하세요
Vipaha 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 47
