주요 콘텐츠로 건너뛰기
모델 A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
433 질문 전체 보기
iMac 2008 where does this wire goes? Solved
I am putting back together this iMac 2008, but I have no idea of where this cable should be connected.
Thank you
Update (01/18/2020)
ok :-) I found it . it goes into the PSU. Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Here’s the logic board connections laid-out as you can see the bottom Power button connection is a two pin connector (one of the few) and it is a single wire connection which is what you have. The switch uses the body case (chassis ground) as the other side.
I’m suspecting the system is not turning on as the power button connection is not connected as that’s what I suspect you’ve got here. But it’s not properly routed. You’ll need to pop out the HD to fix this. Press on the Black upper bracket clip down to snap it out and disconnect the three cables, so you can then fix things.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Below the board. I think it is lower SMD component ( assuming the bents on the wire)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
francoborgo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 51
