주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
How can I tell if my iMac logic board is dead
my iMac will not boot. I have seen the symptoms of impending logic board failure bit I want to be sure
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 6개
Can you get into single-user mode by hitting command-s during boot?
-- N
I cant boot into any mode at all
I have tried all the PMU resets I could find online and no joy
It wont even start up - it is like pressing the power button with the electricity in the house off
From what I can find out, this model iMac is not covered by any extended logic board warranty like the G5 iMacs, so this is now an ex-computer
I had an iMac Intel 2007 (2.4GHz) which has chime and sometimes able to boot fully to Snow Leopard after I open the casing and left the logic board lay outside the casing. Could this be logic board problem or the display board (GPU) problem?
I have a similar problem, with my iMac 20 " EMC 2105, on boot up it doesn't make any chime, the optical drive spins (with disc stuck inside), I tried plugging in a regular (PC USB mouse and Keyboard) and nothing lights up on either one. I only have a wireless mouse and keyboard (APPLE) I am looking at an oversized paper weight at this point but really would like to try and fix it. I shut it down one day and the next day with no warning it just went to a total black screen. Any help out there?
How far does it boot? Try running the usual variety of tests, from install disk, booting from external drive, booting to external display, running the apple hardware test, etc.
Could just be a bad power supply too.
댓글 1개 더보기
댓글 달기
답변 6개
선택된 해법
Some symtoms of a dead logic board are as follows:
No chime
Fan activity
Drives spinning up
nothing displayed on the screen
no power throught USB (or the otherway around)
No Power Through firewire (or the otherway around)
abnormal noises
fans running at max speed
computer heating up abnormally
display image distortion (prior to fail)
이 답변이 도움이 되었나요?
점수 13
댓글 1개:
I'm going to add memory on my iMac at this time should I also replace the logic board? Computer runs sort of fine only problem is memory at 1GB and it runs hot. I'm not sure the fan is running. But otherwise it is my office computer running hard. Always starts.. getting sluggish. Its late 2006/2007 with an odd serial number. Should I replace the drive too? More memory may solve many problems.
댓글 달기
Simple: Remove the Memory modules and if the unit does not give error beeps or flashing LED light, and the LED light remains stagnent you have a Logic Board Issue
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Most likely with these macs its bad capacitors. When you remove the back you will see a lot of swollen caps. they sell the repair kit on ebay if you dont mind changing each and every bad cap.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
So if my MBP isn't showing any response when I hit the power button... no light, no fan, no optical drive activity, no HDD activity, no screen activity, no chime...
What might this be? Doesn't matter what the power source is, same response with battery and AC. I thought it was a bad logic board, but this makes me hope otherwise.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Has there been an answer to this? Our iMac just died one day and we get nothing. they changed out the Power supply and still nothing. Now they are telling me it's the Logic Board (and $800 for the part - less than 30 days after the warranty ran out). Any thoughts???
You said that you have tried the PMU resets. If you don't mind me asking, did you:
1) disconnect the power cord from the rear
2) Wait at least 10 seconds
3) Press the power button in and hold it.
4) While still pressing the power button, plug the power cord back in to the iMac.
5) Release the power button
6) Hold your breath and press the power button to start up your Mac.
Hopefully that did something. If not, You may have failed capacitors on your logic board. Remove the back panel and examine the 26 (I think) capacitors that live on the logic board. they are small round cylinders with cross marks on top. if the top surfaces of the capacitors are dome shaped or have expanded you will need to replace them. Let me know and I can give you the challenging soldering procedure.
This procedure is for the white G5 iMacs
댓글 달기
I have the same problem .
I was listening music and my Imac should down.
I try to turn it on but the computer should down after the apple symbol. After that no more turn on.
I opened and I notice the fans don't work, no video , no sound.
it have 4 led to indicate if everything is ok. all this led are good. Also I can hear the cd player working when I put some cd inside it.
What should I do?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I was listening to music on my MacBook Pro A1502,I went to the bathroom to have my bath came out from the bathroom and saw my MacBook off by itself…I tried the power button severally & it refuses to come on.
what could be the problem?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sean Chandler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 99
전체 시간: 49,036
