주요 콘텐츠로 건너뛰기
Samsung Galaxy S9은 모델 번호: SM-G960XU로 식별됩니다. 2018년 3월에 출시된 9세대 Samsung Galaxy Series 입니다. 색상은 라일락 퍼플, 미드나잇 블랙 및 코랄 블루가 있습니다.
137 질문 전체 보기
Phone screen damaged after repair
I've just finished replacing the logic board in my dead galaxy s9. Prior to replacing it the screen was perfect.
After putting it back together, my screen has a bunch of LEDs near the bottom that won't display blue colors at all.
If I'd have to guess, I might have heated the screen too much when trying to remove the back cover/battery.
Question is, does anyone know any way (dumb or risky to the screen itself) to try and fix this situation other than buying a new screen?
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
I want to fix the screen on my Galaxy s9
댓글 달기
답변 1개
It looks to be either liquid or heat damage. Unfortunately, if moist/heat damage is the case, you will need to replace the whole screen.
Note: Sometimes, heat damage would only damage the polarizer, not the screen. You will need special machines and skill to replace the polarizer without destroying the screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ori Goldberg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 277
