주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Changing iPhone 6s volume silent ringer switch cable need help!
Hi everyone I need some major help
im changing the silent ringer cable and volume cable light cable power cable.
Im having issues re assembling the silent ringer section as I’m finding the ringer switch won’t toggle between the 2. I have only tried without the screws in and also with out the bracket.
Would i I need to put the bracket on first?
Any help appreciated thanks
Update (02/09/2020)
Hi got round that issue but having another issue where the silent ringer switch works with the screen off the phone but with the screen attached it won’t work? Could it be the screen itself ? Or do you think there could be excess plastic on the screen ? Any help appreciated. Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Ok great is there a particular way I should glue it because I purchased just cable and will a bit of super glues do the trick? Thanks
Guys i found the fix the bracket has 2 small bracket hook things on each end I didn’t put the switch inside that which was causing the issue. But now I’m finding another issue with the flashlight which isn’t actually being seated flush to the casing as it’s got 2 things sticking out preventing it from sitting flush any ideas?
댓글 달기
답변 1개
선택된 답변
If the switch works you should try screwing it correctly in place. In case you purchased just the naked cable it needs to be correctly glued to the metal stands, it’s easy to make mistakes in mounting. After wasting many hours in the past, especially with older iPhones that had common power switch issues, I started buying flexes with already mounted metal stands. If you still have issues, a picture might help understanding what the problem really is.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi @arbaman i ha e got round that issue now I have another one, the silent switch is working properly with the screen unattached to the phone, but when the screen is attached it doesn’t move. Do you think it can be excess plastic on the screen because I had to change the screen aswell? Thanks in advance
Hi I fixed the issue it was excess plastic on the screen
댓글 달기
귀하의 답변을 추가하세요
Rakesh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 95
