주요 콘텐츠로 건너뛰기
Apple iPad 1세대는 WiFi와 3G 버전 그리고 16, 32, 또는 64GB 저장 용량으로 출시하였습니다.
266 질문 전체 보기
Screen not rotating when device turned
Suddenly my screen won't change from portrait mode to landscape when I turn the device - only showing in portrait even when turned sideways
Update
Thank you, nicksmacandpchelp and oldturkey03! Got it! :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Try turning device off then powering on, may need just to reset itself
Isn't there a switch by the volume that locks it into place? Have you checked on that and make sure it is properly set.
댓글 달기
답변 2개
선택된 답변
On the side, like the iPhone, only the iPad's locks the rotation, reset that to unlocked and that should do it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have noticed this problem too while using some apps like SKYPE on the IPAD2. When ever an app like SKYPE is crashed or closed. The screen tilting is not working. I think if you restart the device, this is not repeating. This may partly answer your question. But this is what i have identified so far.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shannon Swift 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 1,326
