주요 콘텐츠로 건너뛰기
모델 A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 또는 3.4 GHz Core i7 프로세서, ID iMac13,2
20 질문 전체 보기
after updating to Catalina getting blue bands under windows.
after upgrading a customers iMac from Mojave to Catalina there is this blue hue bar under any white window.
I dont think the upgrade had anything to do with it, its just thats all i have actually done with it since i have had it in our workshop.
Update (01/31/2020)
it looks like a panel fault. but find it strange its only become visible after an OSX upgrade.
the blue hue bar moves and follows the window , its not a static issue.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
What is the exact model you are working on here is it a 21.5" or 27" and what year?
댓글 달기
답변 1개
가장 유용한 답변
This series uses LVDS signaling between the LCD panel and the logic board. Unlike iDP (eDP) signaling, LVDS is sensitive to signal disruption.
Does it look like the system was opened at some point?
It’s likely has a damaged cable or has some liquid damage on the connections where the signal is leaking to the ground lines via corrosion.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
its never been opened before.
after looking at it a bit more the blue hue will remain there if its left there long enough. almost like a type of screen burn.
@chuxsta - What does it look like on an external monitor? Do you see the effect on it or just on the internal display?
@danj
its fine on an external screen, so it leaves graphics and/or panel.
@chuxsta - If the external is clean then that focuses back to the display and/or its connection to the logic board alone. Both internal & external displays leverage the same GPU services.
댓글 달기
답변을 추가하세요
stuart 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 81
