주요 콘텐츠로 건너뛰기
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 질문 전체 보기
The top screen gets power but displays nothing.
Hi.
Some time ago I bought a damaged New 2DS XL. I knew the top screen would not work but replacing was not a problem. After opening it turned out that someone had previously tried to “fix” something and it looks like the picture.
Tape No. 1 is torn out, it has no socket (I know it's NFC) while tape No. 2 is glued (socket is damaged).
Is my fault due to these two tapes? If not, do you have any idea how to fix it? I know the top screen gets power because it gets brighter when I start it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @darkmagenta,
You can try to fix those but that requires some soldering skills and equipment. You can try to get a replacement board but it will be more expensive, especially that both of the tapes look damaged so you will need to replace those components as well.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for your response. I was afraid to change the board. It would be cheaper to buy a new console. That's why I was wondering if it could be repaired in any way.
댓글 달기
귀하의 답변을 추가하세요
Kuba 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 128
