Why does my laptop shocks me when I am using?
There is some parts of the laptop where there is electric shock from time to time. How do i solve it?
좋은 질문 입니까?
좋은 질문 입니까?
Was the system plugged into an AC outlet? If not then you likely encountered a static shock. In the winter the air is so dry it doesn’t take much to build up a static charge so when you touch something that is conductive you can get a shock.
If you have the system plugged into the AC outlet you might have a bad outlet ground connection or the outlet is mis-wired. Go to the local hardware store and get a cheap outlet checker. These can give you a good go - no go view of your outlets power connections.
You may also have a bad charger or power cord. Make sure you are using the proper cord and it’s not damaged.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 303
