주요 콘텐츠로 건너뛰기
The Nintendo GameCube Controller DOL-003. Released November 2001, compatible with Nintendo GameCube, Nintendo Wii, Nintendo Wii U, and Nintendo Switch. Repair for this device is straightforward and requires only common tools.
46 질문 전체 보기
What should I do to Fix My Left Hand Shoulder Button?
My left hand shoulder button isn’t working. I have taken my GameCube controller apart before (to replace Joystick + C-Stick), but now the L.H. shoulder button isn’t working. I think most of the parts are in working order, but whenever I press down on the button, it doesn’t push down as far as the R.H. shoulder button, and makes a slight click. I am also able to wobble it slightly while pressing it down. Pictures below:
Left hand shoulder button:
Controller Inside:
Back of Controller (Left Side)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
it looks like a small bit of plastic to hold the left shoulder button in place broke and is about to come off. It can be put back on with super glue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
u have to align the left shoulder analog slider with the hole on the right side of the left shoulder button. Slide that up while reassembling the controller and then it should work fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nnamdi Obi, 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 279
