주요 콘텐츠로 건너뛰기
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
160 질문 전체 보기
PS Vita 1000 - Cable charging the console, but not transferring data!
Hi!
I have this problem where i ps vita data/charging cable was damaged but i continued using it. One day it Short-circuited and now i cant transfer file from my PC to Vita or vice versa. i can only charge it! Charging works fine.
Its not the cable, i tried other working cables, its the vita it self.
How can i fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi @sonicboi ,
You can check the pins in the port with a multimeter for continuity. Maybe the data lines got damaged.
Other way is to hack your console and use VitaShell which is a file manager that allows you to transfer data via FTP protocol. But this is rather a workaround than a fix.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I hacked my Vita and use WiFi, that's why i want to fix USB data because its broken and WiFi is not so fast and convenient.
I was hoping for some help on actual fixing, schematics of VITA, what to do, where to touch and where not to touch etc.
Bro... Did you manage to fix it? Have you try to see the pins at the charging port? Any burnt pin?
댓글 달기
귀하의 답변을 추가하세요
Sonic Boi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 767
