주요 콘텐츠로 건너뛰기
2018년 10월 26일 출시. Models A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 dual-SIM / 64, 128, 또는 256GB / 검정색, 흰색, 파란색, 노란색, 산호색, 또는 빨간색. ("iPhone 10 R"로 발음합니다.)
448 질문 전체 보기
How do I remove stripped pentalobe screws?
Before you go posting links to articles and videos I have to say I’ve tried superglue, rubber band and duct tape method! One screw is halfway out so I tried Gently using pliers and did not work either. I’m guessing the tool kit I bought from amazon is what did this. The top of the screws are stripped. There’s no grip left because I’m assuming this new pentalobe screwdriver wore it away. Any help is appreciated please just don’t say what I’ve already tried or post links if all it says are the methods I’ve used. I need a new method because nothing is working. Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
if you still have this issue you could try tapping a slightly oversized pentalobe or torx into the screws with a small hammer, it works to pull stripped allen screws sometimes
댓글 달기
답변 2개
Sharpen your pentalope screwdriver first. Apply a bit of alcohol to the stripped screw. Put plastic on top of the screw the try to unscrew
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
on amazon (and elsewhere) there are small ez-out bits which are left hand bits and taps which may work. they come in a pack of 4-5 various sizes. (down to 2 mm). Its a two step method. First is to drill a very small hole in the head of the screw and then use the left hand ez-out to extract the offending screw. I would use a fair amount of downward pressure on the ez-out which is counter intuitive to get the screw to come out towards the force.... I have not used them for such a small screw but they work well for 1/4" screws and larger. You will have to be really careful not to go too deep with the drill but deep enough to have the ez-out to catch the edges of the hole. good luck.
https://www.amazon.com/Damaged-Stripped-...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
clarissa.andrews88 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 411
