주요 콘텐츠로 건너뛰기
2014년 9월 9일에 발표된 이 기기는 Apple의 첫 번째 스마트 웨어러블 출시제품입니다. iFixit의 수리 설명서는 Apple 워치 (스틸) 및 Apple 워치 Sport (알루미늄)에 적용됩니다.
210 질문 전체 보기
Apple Watch series 3 Battery Replacement Overheating
Recently replaced the battery on my Apple Watch Series 3. Connections are intact, but my watch is failing to respond to any attempt to turn it on.
When left on the charger, the watch becomes unusually hot and still fails to respond to attempts to power on the watch.
Battery is connected, force touch sensor is in place and connected. Optical cables are intact and good condition. Screen does have a split towards the edge, but this didn’t prevent the display from function before the battery replacement.
Any thoughts as to what potentially may be wrong?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Try testing your battery for voltage. Anything below 2.6 will be a bad cell.
https://youtu.be/jX1dve5DC-0
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Clearly you have a circuit issue as once the battery is charged the charger should stop charging the battery.
Given the display damage its possible thats the issue as it doesn’t take much to create a short. You could have a deeper issue within the SIP module which is not repairable as thats where the circuit is which controls the charging.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robert Bertram 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 459
