주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Warranty on screen with ghost touch.
I have a iphone X and it is about 20 months old, Apple have a screen replacemt program for the iphone X when the screen has a defect (not when it have a broken glass),
https://support.apple.com/en-gb/iphone-x...
I have made a apointment by Genius Bar last week but in the mean time my phone felt on its back and the rear glass is broken. Will Apple replace the screen or refuse it?
A article on the web show this text :
The waranty does not apply to cosmetic damage, including but not limited to scratches, dents, and broken plastic on ports, or defects caused by normal wear and tear or otherwise due to the normal aging of the device. If no hardware issue is present and cosmetic damage is the only reported issue, then deny a repair or replacement.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Hi. Wanted to know if you got your iPhone X display replaced by Apple?
I have the same problem. The ASP are the only option in India & are denying to replace the display stating silly reasons that it will further damage the back glass!
https://i.imgur.com/ptVuUps.jpg
Yes, Apple have place a new screen under the replacement program for screens that have unresponsive area. But your phone must be without damage, no cracked back glass and front. I did put mine logicbord and unresponsive screen in a secondhand as good as new original Apple backhousing. Prior to visit Apple for replacement.
I see that your's back glass was also broken to so in that case I wanted to know if Apple replaced it for free?
I put mine logicbord and unresponsive screen in a secondhand as good as new original Apple backhousing. Prior to visit Apple for replacement.
댓글 달기
답변 1개
선택된 답변
that would be at the discretion of the particular “genus” you deal with. honestly i would say go to a best buy since they are a ASP and have them do it. ive had them do a few that were defective and just did the back glass myself.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Leslie Leslie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 1,236
