주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2014년 4월 업데이트에는 참신한 듀얼-코어 i5 및 i7 프로세서와 더불어 배터리 성능을 약간 향상시켰습니다.
313 질문 전체 보기
Best way to replace key cups
I’ve taken off some keys on my laptop to see which style keys my laptop has so that I can purchase replacements for worn-out keys. After noticing how dirty one was, I took off some more to clean. In doing this, one of the rubber cups making the contact and triggering the keypress was loose and came off. I was able to refit all keys successfully except the key in question. I used some super glue around the rubber cup of the key, put the cup in place and let the glue dry for a moment. I then replaced the key just as I did for the rest, except this key no longer functions when being pressed.
I’ve removed this key again and cleaned the glue as best as possible. I put the cup in place again and tested if it would trigger the keypress and it would not.
what can be done to fix this key?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
I *haven’t* replaced the cup, but I’d like to. I have a replacement but am not sure how to add the new cup.
댓글 달기
답변 1개
Drill down through the correct group and then click through the pages to the last page which has the domes MacBook Air 2011- 2017 keyboard parts
Depending on how you cleaned the Cyanoacrylate glue off you could have damaged the base at that point you’ll have no option other than replace the entire keyboard.
Use cotton swab with Acetone to take the last bit off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Connor Smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 12
전체 시간: 413
