주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
LCD Screen damaged, replacement part?
Last night my LCD screen got hit and now its broken. I can fix it myself but I need the part. Where can I get the LCD assembly that Apple uses in the MacBook Air 2011 model?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Can anyone tell me if this is going to work on the MacBook Air mid 2011 model?
http://www.dvwarehouse.com/Apple-LCD-Dis...
Thanks for the help!
댓글 달기
답변 2개
선택된 답변
The part you listed and the one Joss listed is for the 2010 model and it may or may not work. At $688, I wouldn't do it. Instead call Apple directly and ask for a quote on a "flat rate" repair. If Apple does it, your warranty remains intact. Apple does not try to make money on a repair of this type. They want to keep you as a customer. If nothing else, it costs you nothing to get a quote from them. Contact Apple here: http://support.apple.com/kb/HE57
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Look lcd for MacBook Air A1370 and with part nr 661-5737 or
MC969ZP
MC968ZP
MC505LL
Z0MG
LP116WH4
B116XW05
http://forums.macrumors.com/archive/inde...
http://www.laptopscreen.com/English/mode...
Here is the guide to take it apart
MacBook Air 13" Mid 2011 Teardown
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Navid 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 9,942
