주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
212 질문 전체 보기
USB/Ethernet/all ports not working
The USB/Ethernet/all other ports on the back of my iMac have stopped working. I plugged a USB cable in and it touched a lamp with a short--it arced and now the USB and Ethernet don't work. The computer boots seems to work fine, but I can't interact with it via keyboard/mouse/ethernet. The airport is off so I can't try connecting via wifi.
My guess is the bus with the ports has been fried. Is this on the logic board, or is it a separate board that's easier to replace?
In addition, any ideas on how to connect/interact with the computer without the use of USB/Ethernet/Wifi?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
You're probably looking at having to replace the logic board. You may be able to get to the bluetooth by disconnecting your keyboard and starting up.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
if you have a bluetooth module, you can try using a bluetooth mouse and keyboard. your imac should ask you pair a keyboard and mouse if you have the bluetooth installed.
as for the damage, the ports are part of the logic board. i have never seen the come seperate. i would have to say
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Reed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 944
