주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
Why does my screen look distorted?
Recently I sent my iPad to be fixed for broken screen (the LCD was intact), they separate the digitizer from the lcd and put a new digitizer on and keep the original lcd.
They did a good job fixing it, but after a day it began to have a distorted screen when I wake up the iPad. It goes away and function normally after a couples of seconds and sometimes for longer. When it goes away the screen looks and functions completely normal, the problem only occurs when the iPad is left a couple of hours not used.
It’s a odd problem, could it be loose cable fitting? Have anyone of experienced the problem before?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Either a loose cable, highly unlikely if they put the metal cover back over the screen connectors or the screen has gone faulty, probably their bad luck from refurbishing the screen.
I have only experienced one similar problem like this but with a full grey screen and rarely showing normal display when trying to lock and wake it up, this is from getting a replacement screen from a supplier (refurbished ones), bought like 10, one comes up like this.
Have to return to back to where it was repaired for warranty :S
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you for reply, I think I will try to open it up and check if there’s any loose cable
댓글 달기
답변을 추가하세요
Mohammed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 20
전체 시간: 350
