주요 콘텐츠로 건너뛰기
Apple's operating system for its Mac desktop and portable computers.
Trying to install El Capitan on iMac
My MacBook is running Mojave and I need to instal El Capitan on my iMac (what was on it before I needed to replace a bad hard drive).
I can’t get it to download using my MacBook through legitimate Apple sources.
HELP! That link Aaron provided is from Apple and since I am running Mojave I can’t download it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
So if anyone had this same problem and could help me before I pull ALL of my hair out that would be greatly appreciated!
Same here, any luck?
did you get to the bottom of this? im in exactly the same situation
댓글 달기
답변 1개
Depending on the age of your iMac you should be able to install your new SSD into your system and then run the Internet restore using the start up keys: Command (⌘) & R keys
Reference: About macOS Recovery
To gain access to the older macOS’s use the startup keys Shift & Option-⌘ & R keys
Reference: Reinstall from macOS Recovery
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
amanda819 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 622
