My NV642 has lost suction and makes a loud noise
My NV642 has lost suction and makes a loud rattling noise. The upper canister part is still working. What is the issue?
좋은 질문입니까?
좋은 질문입니까?
A vacuum cleaner may lose suction for many reasons, but in most of the cased, loud noise is created for severe clog at the hose. It is also a reason for less suction. That's why I am primarily suspecting that maybe there is a clog.
You should try to fix that. To do so, you can follow the steps mentioned in the refered website.
이 답변이 도움이 되었나요?
It is simple to remove a clog in the hose. My 5 year old Shark Rotator was shutting off after 5 minutes on carpet. When I used the hand wand only, the suction was fine. I pulled out the long stick wand, and I was left with 18 inches of hose to clean. The ridges on that rubber hose catch hair, paper, and hard debris that will not get sucked smoothly. Use a wire, dowel or plumbers snake to dislodge the clog. I wish I could post a photo or the massive clog that I pulled out.
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 1,049
댓글 1개
Few days back i faced that kind of %#*@ problem. Reason is less suction…
Jone Edword 의
