주요 콘텐츠로 건너뛰기
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 또는 3.6 GHz quad-core i7 프로세서. 2017년 6월 8일 출시.
176 질문 전체 보기
Fitting second hard drive
I have a 21.5” 2017 iMac which has an Apple blade SSD (SM0512L) fitted.
I have removed the screen from the iMac and the 2.5” drive is totally empty.
I was thinking of mounting a 2.5” SATA SSD in this drive bay, but I am not sure if the SATA connector is in place.
Please confirm whether the SATA connector would normally be in place if a blade SSD has been fitted and if not whether it is possible to order the SATA connector nad mount a 2.5” drive as a second drive (leaving the blade drive as the boot drive)?
If the SATA cable needs to be connected, is it necessary to remove the logic board in order to plug in the cable>
Thanks for any help that you can provide.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The logic board connector is in place you’ll need to install the combo cable (SATA & Power).
iMac 21.5" (Late 2013-2017) SATA Cable
Yes, you’ll need to loosen the board to gain enough room to install the cable
iMac 21.5" (Late 2013-2017) SATA Cable 이미지
상품
$12.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Darrell Haslam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 4
전체 시간: 84
