주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
sprays during rinse cycle
i have a roper washing machine rtw4640yq0. when i wash clothes during the wash cycle the tub fills with water and washes fine, but when n it goes into rinse cycle the tub does not fill with water it sprays the water while draining and the tub does not fill with water. is the tub suppose to fill with water during the rinse cycle or does it just spray water while draining? thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
The newer washer won’t fill up for a rince, they spray while spinning the clothes. You should have a 2nd rinse option or similar to get a full rinse. The owners manual will explain the cycles and operation. Good information in the owners manual.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Hello LadyTech. Question you might know. Have Kenmore model # 11020922990. I have no water filling problem, or water discharge/draining problem as "I fixed the inconsistent fill level & no water during rinse issue" by changing the water level/pressure switch (added the tube clamp, but didn't change the tube yet). Ran several times and all is good EXCEPT, the only issue I think I have now is that it's seems to only spray a little water for about 30 seconds during the rinse cycle after the water drains out? It used to spray more/longer before it goes to the "spin" cycle? Owners manual has no info; Whirlpool doesn't know the schematics, or care. Your thoughts?
Thanks.
@robert51573 i apologize for my late response. The spray rinse is controlled by the timer that sends voltage to the inlet valves briefly. A schematic would show it. The spray rinse is designed for the spin cycle to help remove suds that the spinning creates. Some models will spray water a few seconds at the beginning of the spin cycle when only the pump is running I’ve heard different reason for this and Imost were due to help reduce suds. As long as you’re getting the spray rinses during spin I wouldn’t be concerned. I rarely find a schematic for any newer appliances. They are teaching techs to depend on the diagnostic mode, following a process that shows what circuit the issue is in. I’d rather have the schematic.
댓글 달기
가장 유용한 답변
Sounds like it’s working as designed to me.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Question sir: I have no water filling problem, or water discharge/draining problem as "I fixed the inconsistent fill level & no water during rinse issue" by changing the water level/pressure switch (added the tube clamp, but didn't change the tube yet). Ran several times and all is good EXCEPT, the only issue I think I have now is that it's seems to only spray a little water for about 30 seconds during the rinse cycle after the water drains out? I thought that it used to spray more/longer before it goes to the "spin" cycle? Changed the water inlet valve about 6 years ago, but do you think it could be an issue? Your thoughts?
Thanks.
Yea. My SpeedQueen fills, spins, drains and when almost drained sprays for about 30 seconds and then completes the spin cycle.
댓글 달기
답변을 추가하세요
greg 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 22
전체 시간: 1,279
