주요 콘텐츠로 건너뛰기
모델 A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
433 질문 전체 보기
How to find a part I broke on the power supply
Hello,
I accidentally broke off a part that a wire connects to on the power supply. It connects in a spot labeled CN3. It's black, very small, and has 2 pins. Is this repairable by finding that one part and soldering it on or do I need a new power supply?
The larger board
Zoomed in where the part was, box CN3
Where the connection is
Two angles of the broken part
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개:
Why were in it in the first place?
I was going to replace a fan, but in the process of taking it apart this part broke off the board.
Can you post a couple of pictures so we can see any of the markings on the part as well as where it was located 기존 질문에 이미지 추가하기
OK good! You pulled off the temp sensor connection. I'll need to dig around for the needed part info
I suppose a followup question is this. Would the computer start up if this was the only thing wrong with it? Or would it still work and the temperature sensor just wouldn't?
댓글 달기
답변 1개
how about try to solder that part or find some tiny wire to make as extension, then solder it to the board and part that was been remove but make sure you properly attach the exact connection for both end.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I don't have much soldering experience. But you're saying if I solder the original wires back together it should still work?
Yup as long that you properly solder them in the right connection.
Ever find a solution? Working on a 2008 iMac and the plastic was so brittle the connecter basically disintegrated
댓글 달기
귀하의 답변을 추가하세요
Ben Bradshaw 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 117
