주요 콘텐츠로 건너뛰기
2018년 10월 26일 출시. Models A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 dual-SIM / 64, 128, 또는 256GB / 검정색, 흰색, 파란색, 노란색, 산호색, 또는 빨간색. ("iPhone 10 R"로 발음합니다.)
468 질문 전체 보기
Top 15% screen not working after Replacement
I just performed a screen replacement following an Ifixit guide and using the Ifixit replacement screen. I took my time and Everything went smoothly. When I powered it on the problem is the top 15% of the screen doesn't register any touch input. Everything else works as intended. I took it back apart and plugged the broken screen back in and the touch still works everywhere on the broken screen leading me to believe it's a problem with the replacement screen and not something broken on the motherboard during replacement. I can't see any missing pins on the connectors of the new screen.
Any troubleshooting ideas before I return the screen?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Sounds like faulty screen to me.
Seeing you have configured old screen has full touch function.
Or its even possible the pins on the screen side have been damaged.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
Have you tried plugging in the new screen again or try cleaning the screen cable connector with 99% isopropyl alcohol?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Dalton Magee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 66
