주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
A1466 - WiFi not shown in network
Hello?
Macbook Air A1466, WiFi is not listed in network.
Bluetooth mouse works well, but not recognized WiFi at all.
I checked WiFi module(part) in other Macbook, it works fine.
It seems logic board problem, but where can I check it firstly?
Is it related with WiFi as attached pictures, Y1915?
Thanks a lot in advance!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
The part you have marked Y1915 is a timing crystal running at 24 MHz. It does look like its got some corrosion damage along the left edge as well as some areas around it. This crystal is used by the CPU as its clock so loosing it would be a big problem! So you do need to clean this up and you may need a few new parts.
As far as your WiFi problem, this is not the cause. You likely need to do a bit more inspection looking for more corrosion damage.
While this might be repairable, the amount of effort maybe more than it’s worth. If this is a 1.3 GHz 4GB board I would just replace it with the 1.7 GHz with 8 GB of RAM board as being the smarter direction MacBook Air 13" (Mid 2013-Early 2014) 1.7 GHz Logic Board
Replace a 1.7 GHz logic board (motherboard) in your Mid 2013 to Early 2014 MacBook Air 13" model laptop. Includes 4 or 8 GB RAM. Fix processing issues like unexpected shutdowns, reboots or water damage. 이미지
제품
$125.99
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Good morning HG Jung the easiest way to do this would to be to buy a USB wifi connecter they are dirt cheap and are an easier fix to that
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you for the answer! But, I'd like to fix it by myself.
댓글 달기
답변을 추가하세요
HG Jung 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 636
