주요 콘텐츠로 건너뛰기
Unibody가 아닌 Core Duo & Core 2 Duo 프로세서
375 질문 전체 보기
My screen keeps flickering and I am having problems booting.
Hello, i have a 17 Inch MBP (non-unibody) model A1229.
First, when i boot, i get these two black bars on the edge of the screen, and the spinning wheel on the boot screen had frozen. Here's an image
I had followed the instructions on this page
So i was able 2 boot the MBP. However then i had noticed that the screen was flickering incredibly fast (about 3 times per second) and the computer was unresponsive. I think it may be the graphics card, however i am not 100% sure. Please help D:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hook your machine up to an external monitor to test out the graphics card. There are several things on your link. Which one did you use to be able to boot. You may be having more than one problem. Try booting from your system installation disk and let us know your results. Please give us the last three figures of your serial number so we know your exact machine. There are about 10 models in the A1229 line. Also, can you give us a history of any problems this machine has had?
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I had this problem after replacing the screen on my Macbook Pro A1261. When I 'zapped' the PRAM Battery it solved this – Turn off Laptop, hold down - alt, cmd, P and R buttons and press power button – hold down until mac turns on, turns off and then restarts again.
**I found other key combinations to use on older macs to Zap PRAM are Shift,Ctrl,Alt and power buttons,
Seán
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tristan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 1,002
