주요 콘텐츠로 건너뛰기
Presented at the April 2003 New York International Auto Show, for the 2004 US model year, the Prius was completely redesigned. It became a mid-size liftback, sized between the Corolla and the Camry, with redistributed mechanical and interior space significantly increasing rear-seat legroom and luggage room.
16 질문 전체 보기
it isnt working any more
my car is not working any more
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
# The car won’t do anything, period. When the 12 volt battery fails the car won’t do anything. Jump starting is easy with a little lithium battery pack and instructions are in the owner’s manual. Once started, the big “traction” battery will keep the 12 volts going, but once you turn off the car, the dead 12 volt battery will still be dead and the car won’t do a thing.
# You are in snow or ice and the car is running but it won’t move and the engine won’t rev up: This is because one of the front wheels has zero traction. I discovered this strange effect in a ski area parking lot. The car seemed useless and I accidentally left it turned on and in “Drive” when I got out to go for help. That’s when I saw the left front wheel slowly turning as the car just sat there. I put it in “Park”, threw rocks under both front tires, and I was then able to get moving when I rocked it between D and R.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have this problem too
댓글 달기
you are going to have to get new cells for your prius
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
احمد ابو حماد 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 466
