주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.4GHz, 2.7GHz, 또는 2.8GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
Hangs in boot status bar
I’ve transferred all my data and documents to the new computer and yesterday I had to make a security change (apple, preferences, security) so that I could get both thunderbolt ports working as they were not being recognized. I followed the advice online, shut the computer down using shift, control, option and power at the same time, and now all I get is a loading bar on the screen. I let it go for an hour last night to no avail, and this morning, the same thing.
I’m at a loss what to do.
I’ve included a picture.
Any help or guidance is appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
How did you do this? Using Migration Assistant or Cloning software?
Neither thunderbolt port was working and I did some online research with my sound device and I was told to make sure I had the latest driver,
go into apple>preferences>security and click “allow” on the device. I did that, then restarted, and it never came back online.
Do you have a bootable USB thumb drive? Or at least have one you can make into a bootable OS installer from a second Mac with the same OS level your system is using?
Hi Dan, thank you for helping. I have to admit that I posted here the questions of my buddy Steve, who had theses issues with a machine he got from me.It had been working fine before he transferred his data on it and made the changes his software support folks told him to make. And yes, I do have a bootable mojave installer, and could very well reinstall a fresh copy of OSX mojave if he gets stuck. He is consulting with Apple right now. I told him about you, and the vast knowledge available here as well. The latest from him was this:
"I contacted apple and he walked me through a complete reboot. Nothing else was working. So we changed the name from Mojave to Macintosh HD and I am now installing macOSMojave again. I will most likely transfer my docs and files manually as I backed them up, and have been advised to download applications from the app store or third party websites directly."
댓글 달기
답변 2개
가장 유용한 답변
I have to laugh as the drives name doesn’t matter ;-} The OS installer doesn’t care and neither does the OS or Apps. I really don’t understand why the support person wasted time on that.
But re-installing the OS should fix things, if not he may need to scratch the drive and then re-install.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hey Dan,I came to the same conclusion and will switch out the connector cable here in a minute. Looks like the faulty connector took the lovely OWC 480 SSD drive down with it, it does not even register anymore when I connect it to other macs via USB. That is annoying, because they are expensive SSDs. Anyways I will let you know after the switch. Fortunately I still have a stack of 2011 A1286, since so many bring them to me with the infamous faulty GPU…..Often I replace the logic board in those with 2010 boards, and that restores function. But I still have some empty cases with parts…As usual, humble bow into your general direction, keep on rockin'….
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@jurgenkoppen - Was this comment for your other question?
You really don't want the older 2011 cable as that's only rated for SATA II (3.0 Gb/s) drives which it was shipped with. You really want to get a brand new cable.
Oops, yes, this one got into the wrong thread… thank you for the pointer on the cable re the 2012. I will get a new one then…
댓글 달기
답변을 추가하세요
Jurgen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 15
전체 시간: 165
