주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
iPhone 7 plus homebutton working but fingerpirnt isnt working
Hello Ifixit
I encountered an Iphone 7 plus having an issue on fingerprint sensor the touch id has the same serial with the board itself but when i already boot it up and setting up the fingerprint the fingerprint tab just displays their and not noticing my finger . Double tap to go down is okay and homebutton is working so fine . Can you help me fix the issue ? Thanks i already tried to rearrange the flex cable but still didnt work tried resetting it also etc. nothing works .
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
What led to this problem?
@imicrosoldering Battery Replacement and backcam replacement .
댓글 달기
답변 1개
가장 유용한 답변
Give the display connectors and cables a good inspection. If you creased or tore one of the cables, that could lead to touchID issues. Can you try a new screen?
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Yes like @hootonberg said a new screen should fix this issue.
I already tried a new screen and it didnt work also .
Same with the old one where the homebutton is good(Pressable /Vibrating when being clicked) but the fingerprint capability is not working .
You said you reset the phone. I don’t know what method you used but if you haven’t restored through iTunes I would give that a go it sometimes fixes the problem. If that fails it would point to a failure in the home button assembly.
@imicrosoldering thank you sir will try to restore it on itunes
댓글 달기
귀하의 답변을 추가하세요
Fixie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 61
