Can I repair T-CON Board?
Is there any way to repair the displays T-CON Board?
Help me, I don't have the money to replace lid this moment
Please help me any one?
Update (04/11/2020)
좋은 질문 입니까?
좋은 질문 입니까?
From what I’ve been told you would need to find this chip B1332BDPA 090BX 1605 and have the ability to remove the damaged one and install the new one.
This is not something I would even dream of attempting! You just don’t have the needed tools or skills (even I don’t have them) and as this is a custom part you just can’t get it.
So sadly this is not repairable. You can try to keep your system cool using software which pushes the fans harder TG Pro, but keeping the fans running hard will wear them out if you do this too long as the fans are not designed to run constantly hard. Using your system in a cooler place can also help.
It still gets down to still needing to replace the damaged part (assembly).
해당 답변은 도움이 되었습니까?
Here's are a few others also facing the same issue!
Horizontal line on bottom of MacBook Pro 2017 (Due to overheating)
Horizontal lines on top and bottom screen
You are not alone here!
Thank you very much @danj
Apple should have a recall.. i've been very careful with my macbook, and now i need to spend $700 to replace my screen, because apple did not project a good notebook?
And, is it posible replace the t-con board if i have an other broken lcd a1706 with a good condition t-con board??
@jordi19 - Its serious brain surgery! Nothing you or I could do.
24 시간 전: 0
7일 전: 2
30일 전: 34
전체 시간: 5,738
댓글 6개
Is your display getting worse?
Dan 의
@danj no Mr Dan it's very good but problem are Horizontal lines on top and bottom screen
Dhanu Sam 의
@danj I can understand what you say me. i am a video Editor, than I am using FCPX, come to this problem I can’t work. Because when I using fcpx 10 min Horizontal lines on my screen then I sleep computer few minutes. it’s work 4,5 minutes come again Horizontal lines. but when I use internet download some apps not come Horizontal lines on screen. 1 hour 2 hour can use Never come Horizontal lines.
Because when I open some video YouTube to other site or my HDD can’t show it 3,5 minutes come Horizontal lines on top and bottom screen.
it’s a software problem?????? or Hardware problem???? or Apple company problem ?
Dhanu Sam 의
Yes! - Apple company problem - Bad Design
Yes! - Hardware problem - Need new display to fix no other options!
Your system has two video services the one internal in the Intel chip and the other is the AMD GPU - The AMD GPU creates a lot of heat when used during FCPX the Intel graphics is very limited and only used for light weight processes which does not create a lot of heat! So depending on what you are doing it can appear to be OK and then get bad! Starts off cool then gets hot. If you put your system to sleep the system cools down.
Still need a new display assembly to get the replacement T-CON bd.
Dan 의
@danj Thank you very much sir. TG Pro 2.47 this application can cooled my Mac book pro ???.. so we can complain to apple this problem.. and get claims???
Dhanu Sam 의
댓글 1개 더보기
