주요 콘텐츠로 건너뛰기
2018년 9월 21일 출시. Models A1921, A2101, A2102, A2104. GSM 또는 CDMA / eSIM 또는 nano-SIM / 64, 256, 또는 512GB / 은색, 금색 또는 스페이스 그레이. ("iPhone 10 S Max"로 발음합니다.)
375 질문 전체 보기
What work do I need done?
On my screen, at the bottom right corner there’s a black splotch/blob. It started small and slowly is growing, and now my phone has the ghost touch. Whenever I try to type it’ll start pressing all over the screen. What will fix it? And how much will it cost? Are stores even open now for it to get repaired, due to the coronavirus?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
broken oled you will need to replace the display on an xs max is can get pricey i would just call around to the local repair shops they should still be open (at least around my area they are )
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Denise,
Sounds like your display is faulty, depending on when you purchased the device you may still be under warranty. First step would be to visit apple.com/support and check warranty status. If there’s no other damage to it it may well be covered and they can walk you through the process.
If not you can get it fixed through Apple if you’d like at a cost. It varies between countries a little but visiting https://support.apple.com/iphone/repair/... should give you some idea.
Given that we’re on iFixit, if you’re confident with electronics repair / can follow the guides and want to give it a go. check out https://www.ifixit.com/Store/iPhone/iPho... It sounds like a screen replacement would sort the issue.
Hope this helps!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Denise Nguimdoh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 57
