주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
several problems with iPhone 7
Bad WiFi. Home button doesn't work. Input speaker does not work. People can't hear you when you call them. Voice memo does not work. Headphones do not work , charging port works fine to charge the phone, but headphones do not work when connected .
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I get there's a lot of issues, but was the phone damaged or dropped in water?
Not sure, I bought the phone used
댓글 달기
답변 1개
선택된 답변
so you have an issue that is called audio ic it need to be taken to some one who can do micro soldering that will solve all the issues you have with all of your audio wifi can be replaced if it is damaged with the micro soldering expert also does touch id work but not home button ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
mikespring1972 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 33
