주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
MacBook Pro not turning on?
Hello!
I have a MacBook Pro A1707
It’s a 15inch with touchbar I believe mid 2016-2017
I just replaced the battery and it won’t cut on at all.
I went out and bought a brand new charger and it still won’t cut on
No lights, no fans, nothing at all.
Ive already tried multiple things like Cntrl + Option + Shift, power button.
Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 8개
Who's battery did you use and did you follow the iFixit guide?
I used one off Amazon, I can get the name of it if you’d like. And yes I followed the guide
Did you happen to find out what went wrong? I am having the same issue.
@Misty I. - did you replace the battery yet? MacBook Pro 15" Touch Bar Late 2016 배터리 교체
@Dan - yes, I did. It started to work after I waited for about an hour. I am not sure if it's because my motherboard was somehow drained or had a very low power as I worked on it. I spent several hours since I also replaced both speakers and struggled with the glue.
댓글 3개 더보기
댓글 달기
답변 2개
가장 유용한 답변
If the issue began when you replaced the battery, then the problem may be the battery itself or damage that occurred while replacing it. Try reopening the MacBook and looking for physical damage.
The fact that the battery light doesn’t appear is a clue that the battery is the problem, though.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Shouldn’t it still turn on though without the battery if it’s plugged in?
Also it was having issues before I replaced the battery, that’s why I replaced it. I believe it said replace soon or something like that, and it wouldn’t charge and when I looked, one of the cells were swollen, then I replaced it
@am0960 If it won't turn on with both a new battery and a new charging cord, the problem may be with a motherboard component. Hopefully the swollen battery didn't damage anything, but if it did, the main circuit board may need servicing.
댓글 달기
Have you tried to open it up and look for signs of corrosion or anything? I had my computer sit for a while, and this was the culprit. Ended up taking it into the Apple store, they removed my hard drive, then I bought a SATA-USB cord to get what I had off it.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yes, when I replaced the battery I had to unplug a lot of things and take everything apart. There was no corrosion.
댓글 달기
답변을 추가하세요
annelise mitchell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 28
전체 시간: 1,773
