주요 콘텐츠로 건너뛰기
Repair guides and service information for the VersaMed iVent 201 ventilator.
5 질문 전체 보기
O2 calibration incorrect what may be wrong?
why do i keep getting o2 system calibration incorrect even when i replace the o2 sensor and block inlet port?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
Dear the oxygen sensor must be fully operational.
to calibrate you have to connect a patient circuit with flow sensor. First you have to obstruct the inlet air flow ( if you do not have the correct part, close with a adhesive tape all the hole) and wait until the message to unblock the inlet.
so after waiting for finish process.
any doubt contact me at eric@comprehense.com.br
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you, will do this
댓글 달기
Our fleet of iVent 201’s were having a lot of O2 issues even after O2 cell replacement and successful calibration. What I ended up doing was replacing the wiring harness that goes from the main board to the O2 cell, part# M1161986, I replaced this cable on all 11 of our iVent 201’s and it helped a lot.
I also found the best way to calibrate the O2 is to put the filter in a nitrile glove and then install it in the muffler as a way to seal the inlet very well. If it still won’t calibrate I’ve found that the muffler sometimes isn’t properly sealed up (new out of the PM kit box) and isn’t air tight, so you have to re-seal it (not recommended by GE), or get it replaced by GE under warranty.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
We faced similar problems with our ventilator even after replacing O2 sensor.
Cleaning wiring harness Molex connector with iso propyl alcohol & completing VVT resolved error .
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Dontae Rodney 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 27
전체 시간: 1,356
