주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
653 질문 전체 보기
Got my screen replaced and now the colors are all messed up?
Hello!!
I recently broke my phone screen and got it replaced (not at Apple). The colors of my phone are all messed up now. The contrast + saturation of my screen is really high, and all my pictures look really ugly and distorted now. I tried fixing it in settings in color filters, but it didn’t work; the contrast and saturation are too high. Also my increase contrast is off. What do I do??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 3개
가장 유용한 답변
I’m not one to usually assume things, but I have seen this way too many times and it’s usually caused by the person who completed this repair. Most cases are the person installed a really cheap aftermarket screen and those usually tend to have issues with contrast and saturation. This person also may have skipped this important step when repairing this specific phone found here: https://www.youtube.com/watch?v=xMeAnY_j...
Programming the screen is needed for the light sensor and true tone functionality to work and so many people/repair businesses fail to do so. Do you see any text that says “True Tone” found in settings < display and brightness?
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
yes what do i do after that is there a way to fix it?
Hi toreskey. Is there any way to tell if high saturation after screen replacement is due to lack of TrueTone or low quality of the replacement part? Are there any specific colors that can be analyzed to determine if the problem is caused by not programming the light sensor?
댓글 달기
I have an iPhone XR and the same thing happened to me (off brand replacement screen). I fixed it by using the color filters in the settings (Display & Text Size > Color Filters). I ended up using the Color Tint (the Hue selector was about 1.5 the size of the word “intensity” and the Intensity was between the T and E of it). I hope this helps.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
@jaemeappel thank you so so so much, this actually helped a lot.
Can h help me idk how to do this
@Jaemeappel thank you so much for giving this suggestion. I have an iPhone XS Max that I had to get the screen replaced on two days ago. I took it to CPR store and let them fix it. Ever since I got the screen replaced it has been so bright and it would drain my battery more quickly. I just had the brightness setting barely on. I Googled what to do about the screen and this was the first result that showed up. I did what you said by changing the color filter setting. My screen is now the appropriate brightness it should be. Hopefully this will help with my battery not going dead as quickly. Thank you so much again for posting this.
댓글 달기
My screen is not in colors it always is
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jojo A 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 50
7일 전: 291
30일 전: 1,348
전체 시간: 26,821
